change Teamcenter/RAC directory, as it conflicting with other env
We have created some batch scripts for single client installation for multiple environments,
Scripts are working fine, except one thing it is creating Teamcenter/RAC folder under wrong directory, dur to which it is giving TCCS protocol error..
This is the TcRAC log from that directory...
How can we change Teamcenter/RAC directory? in order to avoid conflicts?
Ganesh
Re: change Teamcenter/RAC directory, as it conflicting with other env
I got to know that, we can change %TC_ROOT%\portal\configuration\config.ini file.
I have changed it.. but my issue still persists
Siemens Legend Siemens Legend
Siemens Legend
The error messages do not seem to have anything to do with wrong directories...
Can you explain in more detail what you have found the problem is?
You can change the TcRAC location by adding the CFG_OPTS to portal.bat (or otwportal.bat) as follows:
set JRE_HOME=%TC_JRE_HOME%
:: Stop old FCC.
%FMS_HOME%\bin\fccstat -stop
:: Location of start_nxmanager
reg add HKCR\ugmportalfile\Shell\Open\command /d "\"%TPR%\start_nxmanager.bat\"" /f
:: Location of Teamcenter\RAC
set CFG_OPTS=
set CFG_OPTS=%CFG_OPTS% -user C:\Siemens\ACME\Temp\%USERNAME%
set CFG_OPTS=%CFG_OPTS% -data C:\Siemens\ACME\Temp\%USERNAME%
set CFG_OPTS=%CFG_OPTS% -configuration C:\Siemens\ACME\Temp\%USERNAME%
:start_portal
