cleanup_ic_objects utility
Hi All,
Requirement is  Addition of new items to above created BOM  through utility
cleanup_ic_objects utility not working
cleanup_ic_objects -u=infodba -p=infodba -g=dba -ic_ad=000070 -key=000019 -ic_rev_id=b005/A
Please help ....I am not getting this syntax
cleanup_ic_objects [-u=user-id {-p=password | -pf=password-file} -g=group]
{ [-ic_id=IC-object-item-ID | -key=IC-object-search-key]
[-ic_rev_id=IC-object-rev-ID] } [-dryrun] [-verbose] [-start_date=start-date]
[-end_date=end-date]
How can we achieve addition of new items to above created BOM
Re: cleanup_ic_objects utility
May be it was a typo,,,
Option name is "ic_id". You have used "ic_ad"..
cleanup_ic_objects -u=infodba -p=infodba -g=dba -ic_id=000070 -key=000019 -ic_rev_id=b005/A
By running this utility no action performed.
Please suggest
