delete dataset
Hi, everyone!
I do not have enough experience inTC  administration and one of the most annoing things is to delete some "wrong" datasets.
jt files created by dispatcher I can delete (with some error pop-up window but still possible)
but i can`t do it for any CATPart ot UGMASTER
where should I dig to find solution? how to remove reference to Item Revision do be able to delete dataset
6 REPLIES 6
Betreff: delete dataset
I assume you're in dba role. if not check the access rights.
Up to TC11 you have to delete the UPPART first before you're able to delete the UGMASTER and ItemRevision.
Check all hidden relations by adding a new preference for DBA group only: WhereReferencePOMPref=1
Michael
Teamcenter UA | NX CAD
thanx for so quick answer.
I have 11.2.3.1 TC version
still have problems with deleting datasets or/and items.
It looks like item should not have any reference but error still says that the instance is referenced and all datasets also unable to delete.
I`ve tried to delete each dataset separetely - only .jt finaly was deleted but all other not - The instance is referenced.
can somebody give me more advices?
You're able to purge the dataset?
Michael
Did you tried deleting the actual reference, like shown below?
Please turn on User settings -> Administrative -> Bypass and try deleting it
Rafa
thanx, Rafa2 for your picture - now I`ve finaly delete those pdf dataset. Previously I picked not correct icon probably.
After that I deleted all other datasets and Item itself
