due ACL changes not able to login
Hello Team,
One of my team member has changed ACL in his TC environment, now he is not able to login in Teamcenter by any login.
We tried infodba/system user as well..
I was trying to run am_install_rule tree on his m/c as we have backup of tree. but there also it is not able to login.
is there any other option by which we can resolve the issue or we have to unistall the TC?
Re: due ACL changes not able to login
You need to set an environment variable in 2-tier:  Set AM_BYPASS=ON   Then you can login as infodba or other DBA account to view and hopefully fix the AM tree.
See GTAC https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=AM_bypass&p=2&file_ty...
