error when click NX in Teamcenter Client 4Tier
hi guys
i found some problem on client side after doing 4tier installation, when i clicked the nx icon is occur error like in picture, is there any someone have found that problem before, or maybe you all guys can suggest how to solving it.
Thanks in Advance
Best Regards
Erhan B
Re: error when click NX in Teamcenter Client 4Tier
If it worked before but after an update the problem comes up I would try to delete the cache.
it was not working since first, its my first experience 4 tier
I think, that this adress should end at /tc - without aiws.
Best regards
Bernard Pacula,
CAMdivision Sp. z o.o.
Consultant PLM/System Architect
the problem just solved, i just recreated Distribution Server Instance and Distribution Server than i redeploy and the error is fixed.
btw thank you for your help bernard i very appreciated.
Best Regards
Erbur
