error while installing 4 tier OTW
Dear friends,
I am trying to instal 4 tier OTW.I am getting some java.net.connctException issue.
please find the snapshot in attachment
Re: error while installing 4 tier OTW
Check if port 12099 is being blocked by firewall on server
Is there is any way to change the port..
Because I don't have access to unblock the port from firewall..
I have changed the port.
But now i am getting another error.
Please give the solution
We need more information to help you. Do you have access to the server where the OTW process windows (or services) are running? It would be helpful to see the Context Parameters of OTW (Distribution Server) and the 4t RAC (Distribution Server Instance).
Evaluating: AW 3.4
Dear Friends,
       I am displaying my start_rmi.bat and start_server.bat here
start_rmi.bat:
@echo off
rem $REVLINE_NO_HISTORY$
setlocal
title RMI Registry
set CLASSPATH=dist_server.jar
rmiregistry 49152
start_server.bat:
@echo off
setlocal
title Distribution Server
java -cp dist_server.jar com.teamcenter.install.otw.ds.DistributionServer
goto end
:end
endlocal
@echo on
and my installing.html file:
-- $REVLINE_NO_HISTORY$ -->
<html>
 <script language="javascript">
 </script>
 <head>
  <title>Teamcenter Rich Client Installer</title>
 </head>
 <body bgcolor="WHITE">
<table border="0" cellspacing="0" cellpadding="0" width="100%" align="center">
         <tr valign="top">
          <td valign="top">
            <img alt="[Teamcenter splash logo]"
            src="images/collage.png" border="0" height="58" width="736"></td>
        </tr>
        <tr>
          <td>&nbsp;</td>
        </tr>
        <tr>
          <td>
            <img src="images/product_name.png" alt="[TBD]">
          </td>
        </tr>
         </table>
         <br><br>
         <b>Installing Teamcenter Rich Client...</b><br><br>
         <br><br>
<table cellspacing="15" style="font-size:12px" cellpadding="2" width="100%" border="0">
         <tr>
          <td rowspan="2" valign="top" align="right" width="100%">
            <img src="images/company_logo.png"
             alt="[Siemens]"
             border="0" height="32" width="180">
          </td>
          </tr>
        </table>
        <br>
                 <br>
  <object classid="clsid:8AD9C840-044E-11D1-B3E9-00805F499D93"
  codebase="http://java.sun.com/update/1.5.0/jinstall-1_5-windows-i586.cab#Version=1,5,0,0"
  onerror="" WIDTH="1" HEIGHT="1" VIEWASTEXT>
   <param name="CODE" value="com.teamcenter.install.otw.installer.Installer">
   <param name="type" value="application/x-java-applet;jpi-version=1.5">
   <param name="scriptable" value="false">
   <param name="archive" value="otw_installer.jar,jdom.jar,commons-lang.jar">
   <param name="instance" value="AMW_TC56_Distribution_Instance">
   <param name="server_name" value="AMW-WS-056.amwasia.com:49153">
  <comment>
  <EMBED
   type = "application/x-java-applet;version=1.5" \
   CODE = com.teamcenter.install.otw.installer.Installer \
   ARCHIVE = "otw_installer.jar,jdom.jar,commons-lang.jar" \
   WIDTH = 1 \
   HEIGHT = 1 \
   scriptable = false \
   pluginspage = "http://java.sun.com/products/plugin/index.html#download"
   instance="AMW_TC56_Distribution_Instance"
   server_name="AMW-WS-056.amwasia.com:49153">
   <NOEMBED>
    alt="Your browser understands the &lt;APPLET&gt; tag but isn't running the applet, for some reason."
   Your browser is completely ignoring the &lt;APPLET&gt; tag!
   </NOEMBED>
  </EMBED>
  </COMMENT>
  </object>
 </body>
</html>
endlocal
@echo on
Let me know any other files you need..
Please help me to sort this issue
Hi Ganesh,
As per the data on my server, I see that the same port number from in Installing.html  has to be used in start_rmi.bat.
In your files it seems to be different. Installing.html uses 49153  (param name="server_name" value="AMW-WS-056.amwasia.com:49153")  while start_rmi is using 49152.
Another suggestion: If the requirements permit, you can also use tem.bat to install 4-Tier RAC instead of OTW
I have tried by changing the port in start_rmi.bat.But still the same problem exist.
any other suggestion pls
