feature deployment error.
Siemens Creator
Every Feature I am trying to install through TEM is getting failed showing following error.
ERROR: Unprocessed schema and/or non-schema updater transactions exist
BMIDE log  attched with this.
Re: feature deployment error.
constant does not exist. check this constants
Looks like you have some data model issues.
Are deploying some change? perhaps removing a Business Object?
