getting error while running backup_xmlinfo
Hi ,
We have replicated an environment from one server to another. I have changed all conifguration files mentioned in below link,
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/How-to-create-Test-e...
I am able to connect with the database in new environment. When I ran "install -ayt" i am getting the success message.I am able to run regen_schema_file.
But,when I ran backup_xmlinfo utility ,I am getting below error. Running any Teamcenter utility, ending with below error. Log file is also not get generated. Please provide your suggestions.
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libFnd0disclosure.so: symbol __1cKTeamcenterTWorkspaceObjectImplTsetLicense_listBase6MrknDstdGvector4CIn0CJallocator4CI____pkn0CGvector4Cin0CJallocator4Ci_____i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libfnd0absactionitem.so: symbol __1cKTeamcenterTWorkspaceObjectImplTsetLicense_listBase6MrknDstdGvector4CIn0CJallocator4CI____pkn0CGvector4Cin0CJallocator4Ci_____i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libFnd0qualification.so: symbol __1cKTeamcenterTWorkspaceObjectImplTsetLicense_listBase6MrknDstdGvector4CIn0CJallocator4CI____pkn0CGvector4Cin0CJallocator4Ci_____i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libFnd0editcontext.so: symbol __1cKTeamcenterTWorkspaceObjectImplTsetLicense_listBase6MrknDstdGvector4CIn0CJallocator4CI____pkn0CGvector4Cin0CJallocator4Ci_____i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libFnd0emailpolling.so: symbol __1cKTeamcenterTWorkspaceObjectImplTsetLicense_listBase6MrknDstdGvector4CIn0CJallocator4CI____pkn0CGvector4Cin0CJallocator4Ci_____i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libFnd0nweditor.so: symbol __1cKTeamcenterIItemImplMsaveInstance6MIpn0AIBulkData__i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libsecore.so: symbol __1cKTeamcenterIItemImplMsaveInstance6MIpn0AIBulkData__i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libMem0memmgt.so: symbol __1cKTeamcenterTWorkspaceObjectImplTsetLicense_listBase6MrknDstdGvector4CIn0CJallocator4CI____pkn0CGvector4Cin0CJallocator4Ci_____i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libcondvalidation.so: symbol __1cKTeamcenterIItemImplMsaveInstance6MIpn0AIBulkData__i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libproductvariant.so: symbol __1cKTeamcenterTWorkspaceObjectImplTsetLicense_listBase6MrknDstdGvector4CIn0CJallocator4CI____pkn0CGvector4Cin0CJallocator4Ci_____i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libccdm.so: symbol __1cKTeamcenterTWorkspaceObjectImplTsetLicense_listBase6MrknDstdGvector4CIn0CJallocator4CI____pkn0CGvector4Cin0CJallocator4Ci_____i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libcontmgmt.so: symbol __1cKTeamcenterTWorkspaceObjectImplTsetLicense_listBase6MrknDstdGvector4CIn0CJallocator4CI____pkn0CGvector4Cin0CJallocator4Ci_____i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libissuemgmt.so: symbol __1cKTeamcenterTWorkspaceObjectImplTsetLicense_listBase6MrknDstdGvector4CIn0CJallocator4CI____pkn0CGvector4Cin0CJallocator4Ci_____i_: referenced symbol not found
ld.so.1: backup_xmlinfo: fatal: relocation error: file /apps/tc_vsem/11.2/sun/lib/libschmgt.so: symbol __1cKTeamcenterTWorkspaceObjectImplTsetLicense_listBase6MrknDstdGvector4CIn0CJallocator4CI____pkn0CGvector4Cin0CJallocator4Ci_____i_: referenced symbol not found
Re: getting error while running backup_xmlinfo
There was no access for few files. So that Igot below error. Now I am able to run the utilities.
