hide Where Referenced(POM) option from non-dba
How can we hide Where Referenced(POM) option for non-dba users? When switch to DBA account that option would show up.
Thanks!
1 REPLY 1
Re: hide Where Referenced(POM) option from non-dba
The "Where Referenced (POM)" feature for Impact Analysis is enabled by setting a preference (WhereReferencePOMPref=1). You can remove this from the "dba" Group setting and use it as an individual User setting. It is not in place by default so this is something that has been added to your environment.
