how to change infodba password?
i install teamcenter 11 and now for login i set username and password :infodba/infodba
but show me login error password is mistake
i cannot login to teamcenter, how i can change password for infodba account?
thanks
Re: how to change infodba password?
Do you have another Teamcenter dba user?
If so, let that user reset the infodba password.
If you don't run make_user and use -pf argument for the password and create another dba user if the utility does not let you reset the password for the infodba.
make_user -u=infodba -pf=password-file -g=dba etc.
The password file is created by tem and it is under %TC_ROOT%\security.
i dont have another account,
i have now the new error,
new error:
com.teamcenter.soa.client.SoaRuntimeExceptionSmiley TongueOM has not started
please help me
i can connect to sqlplus with username: infodba and password: infodba
but cannot login on the teamcenter and show me the password is invalid
error is attached
please help me
Chul Kim has given you some excellent advice. Leverage the password file since you don't know (or remember) the infodba password by using the "-pf" argument while running "make_user" to create a new dba account. Use this new account to log in and change the infodba password.
Note: you MUST have a valid license file or you are in violation of the software agreement.
Best,
/Randy
Evaluating: AW 3.4
I install first time teamcenter rich2 client and change management and set username: infodba and password: infodba
last time i install with enviroment manager so many other fetures and module, and dont change username and password from me,
but when run teamcenter icon from desktop and set username:infodba and password:infodba
and show me
password is invalid
this cod from c:\Siemens\Teamcenter11\security
lycGeSoFzEtOvx6PFaPz2ETej7bG90v2RJKm0g9QZ6k
please tell me how to do it
i got answer
Teamcenter security services error
Similar issue for me :-
Even make_user doesn't work....
- Iam using TC11.2.1
- I have local database where I dumped the DMP
- To change infodba pwd in the DB, I used update ppom_user etc et....with a known encryption
- used to work untill TC9 or TC10
Anything changed since TC10 on updating encrypted pwd in DB
PPOM_USER table holds Teamcenter, not Oracle, user information.
To change the infodba password use Oraganization module.
Thanks for your reply. My question is to find out if there is a chance to change infodba pwd
in DB, without going into organization structure i.e without login/opening or even accessing RAC.
