how to create Table format in Teamcenter 10.1.7
I am trying to to create Table format in Teamcenter 10.1.7 with String array property define in BMIDE.
But failed to do the same, If any one have some solution for the same Pl share..
Betreff: how to create Table format in Teamcenter 10.1.7
Please describe you problem in more detail!
In BMIDE create new property from type TABLE on your IRev.
Define name and the name for the table row business object. -> select NEW to move to the next dialog to add each row of type string (or other type). Finish creation and deploy.
Michael
Teamcenter UA | NX CAD
Hi, Thanks for reply !!
In Teamcenter 10.1.7 TABLE type property is not available, It is introduce in version 11.2 onward.
I want to provide table format data (15 rows X 10 column) in summary tab of rich client, for these we have create business object and define 10 string array property in same. Now we have taken input from user through RAC form and same inputs need to be store in defined sting arrays in RAC But failed to do the same.
If any solution Pl help to do same..
