input file format for ps_upload utility to create multiple item revision revisions
Builder
Builder
I am able to use ps_upload to create items. When i try to create multiple revisions for the same item, I get an error "found existing item id" and the revision does not get created. Below is the input file data for ps_upload.
#DELIMITER ~
#item~name~rev
045661~PSTEST1~A
045661~PSTEST1~B
045661~PSTEST1~C
045662~PSTEST2~B
045662~PSTEST2~C
045663~PSTEST3~B
Below is the commandline arguments passed to the utility
ps_upload -u=infodba -p=infodba -g=dba -c=Item -t=HCast -v -i=D:\Loader\psUpload_InputFile_Test.txt
Below is the console output.
read in structure: (id,name, level, seq_no,no_of_occs, qty_per_occ, uom, subs)
item_id=045661/<System Assigned RevID> PSTEST1, 0, HCast, 1, 0.000000, , Item
New item created item_id=045661
Found existing item item_id=045661
item_id=045662/<System Assigned RevID> PSTEST2, 0, HCast, 1, 0.000000, , Item
New item created item_id=045662
Found existing item item_id=045662
item_id=045663/<System Assigned RevID> PSTEST3, 0, HCast, 1, 0.000000, , Item
New item created item_id=045663
I am creating single items with multiple revisions. Once the item and item revision created, i intend to use load dataset for all the revisions.
Any suggestions would be helpful.
Santosh
Re: input file format for ps_upload utility to create multiple item revision revisions
What version of TC are you using? If you are on TC10.1.4+, then I highly suggest that you use TCXML to load your items. I can point you in the direction of the documentation if you are interested.
Jamie Griffis
Mercury PLM Services
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
Builder
Builder
Jamie,
I would like to know more abt TCXML. Will try this approach also.
I would also like to know what is the mistake in my ps_upload input file.
Santosh
Builder
Builder
Jamie,
Thanks for the input and pointing me to right direction. Will surely look into this approach.
Santosh
Hi, did you ever find out what the mistake was in your input file that was yielding the error when trying to create multiple revisions of the same item?
Builder
Builder
No. The tcxml approach suggested by @jamie was much faster and better to understand. Never bothered to find the issue. You can do most of the things which ps_upload does using tcxml.
Santosh
