ipem 11.4 for Creo Model Import
I am trying to import 3 creo assemblies into teamcenter using ipemimport. The first being single level and the other two being multi-level.
The single level assembly could be loaded using a bottom-up formed ipem instruction file. I haven't been able to replicate the method for multi-level assemblies. What is the trick I am missing?
Hopeful soul.
Re: ipem 11.4 for Creo Model Import
For anyone who might be interested. The upload of multi-level assemblies is the same as a single level assembly. My error was because of having a family part with a generic and several instances.
All the instances need to be specified under the generic in the instruction file for a successful import.
