ipem import utility failure
I'm trying to use ipemimport utility from the command line and i'm stuck up at a point where ipemimport tries to open up a Creo session.
The command line prints, port binder error before it fails and captures the information that it couldn't open a Creo session in the log file.
Has anyone faced this issue before and any guide/solution for this?
Re: ipem import utility failure
probably someone is consuming the license
