is it possible to add at Item DisplayName constant custome property of ItemRevision?
Hello, everybody!
I want to figure out is it possible to make Item Display Name with some custom property of Item Revision?
for example:
$item_id+"-"+$r4_CustomPropertyofItemRevision
to see in My Teamcenter something like this:
000001-CustomPropertyofLastItemRevision
or it could be done in some other way? please advise
Re: is it possible to add at Item DisplayName constant custome property of ItemRevision?
You should be able to do it. Did you already test it?
With TC 10 I faced some issues with the updating of the displayname. Seems to be fixed with TC 11.2
xtof
'r4_CustomPropertyofItemRevision' must be on item as a compound property if 'r4_CustomPropertyofItemRevision' needs to be included in Item DisplayName (BMIDEbusiness constant DisplayName).
Please let us know if this approach works for you.
Harish
