latest baseline display ontop
Builder
Builder
Hi, all
So I just ran across this figure on a website. It has its lastest baseline displayed at the top, item revision at the bottom.
How am I able to get that configuration display on my teamcenter? We want the same too. Thanks all!
update: this is can be done througn setting with  item_rev_display_rule preferences. But We used OOTB item type, this preference doesn't work on these item type. Any idea how to deal with that?
3 REPLIES 3
Re: latest baseline display ontop
For Item, I am able to set the displayable revisions using 'Edit --> Options --> Item --> Display...'
Untitled.jpgItem Displayable Revision
Do you have 'displayable_revisions' as a value in 'Item_DefaultChildProperties' preference?
Harish
Builder
Builder
Thank you first.
I did see them. But it only changed the display rule for OOTB item type on the left. For our item type, I have played around with all settings, they're just like dead bodies and won't change....rev_display.png
Builder
Builder
just a quick answer. in the option->item-> display, you can select item type. I chose OOTB item, soooo it changed the display rule. Then I select our PT item, it worked.
