licesnse s
Siemens Creator
Is there anyway to check to whom license server is consuming from differnt machine.is there any monitering kind of client for license from omeone can check how much users are using that server
Re: licesnse s
On the license server there is the LMUTIL command line utility, that can be used to list the active licenses.
Utility usage information:
lmutil -help
Display the current license usage:
lmutil lmstat -c 28000@LicenseServerName -A
Hope this helps.
Re: licesnse s
Siemens Creator
but I can use this utility only on license server, How can I use this utility on different machine without installing license server? or is there anyother way?
Re: licesnse s
As far as I know, the LMUTIL executable doesn't need any support files, so you could just run it from a USB stick without any need for a installation.
Re: licesnse s
In other words, you can run it locally against the license server specified in the "-c" argument. You don't need to run it directly on the server.
