no one can use Classification Admin except me?
Builder
Builder
Hi, experts,
We had this problem that no other dba can use Classification Admin but me.
So I was the first one to get in there use CA module. I created a hierarchy. Then other dba wants to use it, the error message pops up as below. I am assuming every dba can go in there and change it. Did I miss some additional setup?
I also I am not able to delete a storage class. It is referenced while nothing in it and under it, that is no sub-class, no ICO classified in it. How to check what else is referenced in Classification Admin..
 Finally, is this a crucial problem that I should contact GTAC? Thanks guys!!!
Re: no one can use Classification Admin except me?
I would first check if there are sufficient licenses to cover dba users using classification admin (classification_author).
Does Teamcenter syslog for the session throw any clues? license issues or something else?
Harish
The issue ma be in licenses that not enougth.
Dont forget about new siemens licencing policy - naming license is attach to end users for a month after they'll do first check-out. Even you disactivate user in organization application the license still be attached to user.
It's teamcenter license tracking function
