open PDF_References from tc (when WPS office installed in machine)
Hi Team,
If we have WPS office installed in our machine and we try to open PDF_References. Its opening pdf's with WPS office only, instead of Adobe reader. Could you please suggest any help !!!! [attached screen grab]
Re: open PDF_References from tc (when WPS office installed in machine)
This is a windows registry issue and not anything to do with Teamcenter. Check your value(s) for HKCR\.pdf
Googled it...
https://www.adobe.com/devnet-docs/acrobatetk/tools/AdminGuide/pdfviewer.html
According to Adobe...
To make Reader the default PDF handler after installing Acrobat, find and run ADelRCP.exe in elevated mode.
Evaluating: AW 3.4
