owning_site in multisite
can someone please explain what is owning_Site in Teamcenter? Also what is significance of real_owning_site and remote site?
Re: owning_site in multisite
They are properties that can be populated with values. Their value is in their usage. If you don't use them they have no value. You didn't say which object the properties belong to so I must assume that you are speaking generally. Generally, these properties are related to multisite and keeping track of the "golden copy" between sites. Only one site can have write access at a time while all others have a read-only copy.
Evaluating: AW 3.4
