problem facing in tcin_template_setup
Facing issues with  importing templates.
Error: Couldn't initialise Unigraphics
 ug_clone import operation failed.
Re: problem facing in tcin_template_setup
Run this tool in enhanced CMD.
there was the problem with license server name in tc_profilevars, since xe_tc10.bat(teamcenter command prompt) sets this .
Solved Now. Thanks :)
