cancel
read access to dataset based on a property of it's item revision
I want to remove read access to some datasets from certain users (ignore the group of users I can do that) if a property of the revision master form of the specification related revision is a certain value.
The form property has been made a compound property on the Item Revision.
I want this for datasets of any type from UGMaster, UG part, MS excel, MSWord and so on and for item revisions of both Design and document.
I can hide the revision using "Has Form Attribute" but that does not affect datasets which a user could still search for it. I was thinking of some sort of has property but would I set a compound property on the dataset class?
