revision_list property
my requirement is to get the latest ItemRevision from Item using SOA if an itemRevision is input.
My question is: will the last revision in revision_list property always give the latest revision ?
In other words, does revision_list property always returns itemRevision in sequence of creation ?
Thanks!
4 REPLIES 4
Re: revision_list property
I think "sequence of creation" are the right words to use. Revisions are ordered by creation date.
Evaluating: AW 3.4
Something like this works for me but I never checked if I really get the lastest revision if users are doing some weird things on revising in TC.
ItemRevision lastRev = item.Revision_list[item.Revision_list.Length - 1]
Thank you for your responses.
@xtof: That's what concerns me and therefore want to make sure if there could be such a case.
I could not find anything in TC Doc about this, do you guys have an idea ?
After the discussion with my colleague today the requirement was clarified and as the requirement does not demand that accuracy regarding creation date.
So I can conclude this discussion here. Thanks again for your responses :)
