syntax NX mapping for get back two roles for SIGNOFF
Hello everybody,
I still can't doing the mapping correctly between NX and Teamcenter.
Here's a description for my problem:
By default, in the txt file using for mapping, I have the line below:
"VERFIE: ItemRevision.Job.SIGNOFF(<Name Review Task>, <name role>).group_member.user.person.user_name /master=iman"
Question:
I would like to assigne two roles as parameteres for the TaskReview's SIGNOFF.
I tried the syntax below, but it doesn't work:
"VERFIE: ItemRevision.Job.SIGNOFF(<Name Review Task>, <Name role 1>;<Name role 2>).group_member.user.person.user_name /master=iman"
Thank you in advance for help.
Best regards,
Re: Impossible to assign two roles for a TaskReview's SIGNOFF
Unfortunately, I come back to you beacause I didn't find any solutions to resole my problem.
I will be grateful I someone can give a clue.
Thank you.
Likely you will need to break this up into two separate SIGNOFF mappings:
"VERFIE1": ItemRevision.Job.SIGNOFF(<Name Review Task>,<Name role 1>).group_member.user.person.user_name /master=iman
"VERFIE2": ItemRevision.Job.SIGNOFF(<Name Review Task>,<Name role 2>).group_member.user.person.user_name /master=iman
Evaluating: AW 3.4
Thank you for replying.
In my case I want one approver as  "Teamleader" and onther as " Design Engineering".
So there is one type of role who approve between both.
Your solution it's work but not the ideal in our case.
Do not hesitate if you have an other clue.
Thanks.
