tcin_cam_template_setup error 720117 - Naming application failures occured during this operation
We have some trouble when attempting to imporn NX10 CAM setup templates with tcin_cam_template_setup.bat
We got this error:
720117 - Naming application failures occured during this operation while  performing import.
ug_clone import operation failed.
On GTAC we found recommendation to check preferense TC_MFK_DEFAULT_DOMAIN=Item. The preferense value is 'Item' but this not close the issue.
TC 10.1.5
NX 10.0.3
What else can be reason of 720117  error?
Re: tcin_cam_template_setup error 720117 - Naming application failures occured during this operation
Problem solved. The reason was in preference Tc_part_display_filter where MENCMachining value was absent
