tcserver no response received in 4-Tier,Web-Tier and AWC
Hello all
I can connect TC from 4-Tier,Web Tier and AWC.
I always show tcserverX@8085@XXX@XXXX : No response received.
But I check admin tcserver@tct is working.
How I can slove it? Where I need to check?
Help please.Thank you!
Best Regard.
Best Regards
David
Teamcenter 11.4,Active Workspace 3.4
Solid Edge ST10
Re: tcserver no response received in 4-Tier,Web-Tier and AWC
Builder
Builder
Check your webtier connection via thin client.
If the error still occurs, check tc pool windows services and restart the server and try again.
Hello sma
I did it all.
But still not working.
Best Regards
David
Solid Edge ST10
I was with the same problem, then I solved using the following command in the administrator prompt:
NET START W3SVC
Because the Default Web Site wasn't starting, and with this command is working normally.
I hope helped you.
Igor Pollo
Hello igorpollo
I reinstall patch and it solved.
But if it happen again,I will try it!
thank you!
Best Regards
David
Solid Edge ST10
