teamcenter 4tier Rich Client 11
hi friend
i install teamcenter on my server and now i install temcenter 4tier Rich Client 11 to my client machine and now i run temcenter 4tier Rich Client 11 to client and software will not run and closed automaticlly without any respond.
all service on teamcenter server is runing
Teamcenter Pool Manager is run
Teamcenter FCS Services is runing
SPLM License Server is runing
Oracle all service is runing
Weblogic is runing
RMI s runing
Distribution Server is runing
but after click temcenter 4tier Rich Client 11 icon on client machine closed automaticlly without any work
thanks
3 REPLIES 3
Re: teamcenter 4tier Rich Client 11
Try dragging and dropping the TC icon to a command window as it may give you a better idea of what the problem is. Probably Java.
Best,
/Randy
Evaluating: AW 3.4
Launch a Command Prompt.
C:> cd %TC_ROOT%\portal\registry
C:> genregxml.bat
After the command completes, try 4-tier RAC again.
If you get the same error:
Show Java console and enable tracing and logging (Control Panel --> Jave --> Advanced)
C:> portal -clean -command -console
The above will show you more information.
mismatch java version between server and client machine, java version 1.7 is compatiblate and stable
thanks
