teamcenter replica
hi
everyone
I am trying to install a teamcenter replica ,
I ran tem.bat "as administrator" all the process OK and in the end I get this error
The command manage_model_files.exe failed with a return status of 515003.
++++++++++++++++++++++++++++++++LOG++++++++++++++++++++++++++++++++++++++++++
 Executing ["C:\app\team\Teamcenter10\bin\manage_model_files.exe" -u=infodba -p=***** -g=dba -force=model -option=upload]
Output from command: "C:\app\team\Teamcenter10\bin\manage_model_files.exe" -u=infodba -p=***** -g=dba -force=model -option=upload
Processing File: activeworkspacebom_dependency.xml
3072: The FTS engine could not be found.
515003: The application is not privileged.
command_exit=515003
Exit Status 515003, elapsed time 0:00:02
An error occurred during execution. Stack trace follows...
com.teamcenter.install.tceng.base.DatabaseSteps.manageModelFiles(DatabaseSteps.java:3042)
com.teamcenter.install.tceng.base.DatabaseSteps.manageModelFiles(DatabaseSteps.java:3103)
com.teamcenter.install.tceng.base.DatabaseSteps.install(DatabaseSteps.java:282)
com.teamcenter.install.tceng.base.Foundation.install(Foundation.java:187)
com.teamcenter.install.tem.tasks.JavaTask.execute(JavaTask.java:162)
com.teamcenter.install.tem.tasks.Task.execute(Task.java:120)
com.teamcenter.install.tem.tasks.blocks.CodeBlock.execute(CodeBlock.java:201)
com.teamcenter.install.tem.struct.TcFeature.processAction(TcFeature.java:1350)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:1288)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:1188)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:1102)
com.teamcenter.install.tem.struct.TcFeature.install(TcFeature.java:1027)
com.teamcenter.install.tem.director.actions.InstallAction.execute(InstallAction.java:29)
com.teamcenter.install.tem.director.DirectorScript.execute(DirectorScript.java:142)
com.teamcenter.install.tem.director.Director.run(Director.java:120)
java.lang.Thread.run(Thread.java:744)
com.teamcenter.install.tem.struct.exceptions.UserCancellationException: User cancelled
Re: teamcenter replica
Is this a replica from an environment where you had FTS installed in database and in this replica environment you do not have FTS installed? This is what i can guess just looking at the trace
 SRaj
I have installed FSC.
I require something more ?
