two clients on same workstation
Builder
Builder
Hi everybody,
Before I go any further, I searched a little but no luck. I know you can have two clients refering different databases on a same workstation.
My situation is that, I wanted to install a standalone environment separated from all, test and prod. My workstation has a rich client connected to test server. I installed a SQL server and ready to install a new 2 or 4 tier that will uses my local database.It is because I have all the other software installed on this PC, and I dont want to lose them...
Is this possible? anything I should keep an eye on?
Re: two clients on same workstation
See these articles for installing multiple clients on the same workstation...
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/Connect-to-another-T...
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/Pool-Manager-startup...
Let us know if you have more questions.
Evaluating: AW 3.4
