unable to start FSC service
Hi Buddies,
I am trying to Replicate our Production server into a test server.I have populated the back up of production server and renamed the host id and SID in tcprofilevars.bat and tnsname.ora files.
I am trying to edit the FMSmaster xml file after running backup_xmlinfo utility..
After this i have tried to restart the FSC service but i am unable to start the service.
Need help on this..
I have attached the error snapshot with this
Re: unable to start FSC service
Check the TC_ROOT\fsc\FSC_*.stdout and FSC_*.stderr for more information on why the FSC won't start.
Evaluating: AW 3.4
Dear Randy,
I have viewed FSC_*.stdout and this is the error
16/06/29-10:21:15,743 UTC MLD Log init: com.teamcenter.mld version 1.0.2 (2009-01-21)
log.properties found at C:\APLM\Siemens\TEAMCE~1\fsc\log.properties
INFO - 2016/06/29-10:21:15,930 UTC - AMW-WS-056 - FMSServerCache starting...
INFO - 2016/06/29-10:21:15,930 UTC - AMW-WS-056 - FMSServerCache version: 8.2, build date: 20110407
INFO - 2016/06/29-10:21:15,930 UTC - AMW-WS-056 - FMSUtil version: 8.2, build date: 20110407
INFO - 2016/06/29-10:21:15,930 UTC - AMW-WS-056 - FSCJavaClientProxy version: 8.2, build date: 20110407
INFO - 2016/06/29-10:21:15,930 UTC - AMW-WS-056 - java.vm.version: 14.0-b16
INFO - 2016/06/29-10:21:15,930 UTC - AMW-WS-056 - java.vm.vendor: Sun Microsystems Inc.
INFO - 2016/06/29-10:21:15,930 UTC - AMW-WS-056 - java.vm.info: mixed mode
INFO - 2016/06/29-10:21:15,930 UTC - AMW-WS-056 - java.io.tmpdir: C:\Users\infodba\AppData\Local\Temp\
INFO - 2016/06/29-10:21:15,930 UTC - AMW-WS-056 - java.library.path: C:\APLM\Siemens\TEAMCE~1\fsc/lib
INFO - 2016/06/29-10:21:15,930 UTC - AMW-WS-056 - file.encoding: Cp1252
INFO - 2016/06/29-10:21:15,946 UTC - AMW-WS-056 - line.separator: CRLF
INFO - 2016/06/29-10:21:15,946 UTC - AMW-WS-056 - user.name: infodba
INFO - 2016/06/29-10:21:15,946 UTC - AMW-WS-056 - user.home: C:\Users\infodba
INFO - 2016/06/29-10:21:15,946 UTC - AMW-WS-056 - user.dir: C:\APLM\Siemens\TEAMCE~1\fsc
FATAL - 2016/06/29-10:21:16,086 UTC - AMW-WS-056 - Error during initialization. com.teamcenter.fms.servercache.FMSServerCache
com.teamcenter.fms.config.DuplicateConfigurationElementException: Duplicate 'volume' configuration elements were found for attribute 'id' with value '00f34e3fde9183042f03'.
at com.teamcenter.fms.config.ChildFileStoreInfoProcessor.processChildFileStoreInfo(ChildFileStoreInfoProcessor.java:70)
at com.teamcenter.fms.config.FSC.processElement(FSC.java:344)
at com.teamcenter.fms.config.FSCGroup.processElement(FSCGroup.java:251)
at com.teamcenter.fms.config.FMSEnterprise.processElement(FMSEnterprise.java:396)
at com.teamcenter.fms.config.FMSWorld.processElement(FMSWorld.java:91)
at com.teamcenter.fms.config.FMSConfigParser.parseFMSConfigFromDocument(FMSConfigParser.java:707)
at com.teamcenter.fms.config.FMSConfigParser.parseFMSConfigFromFile(FMSConfigParser.java:534)
at com.teamcenter.fms.config.FMSConfigParser.parseMasterConfig(FMSConfigParser.java:377)
at com.teamcenter.fms.config.FSCConfiguration.<init>(FSCConfiguration.java:383)
at com.teamcenter.fms.config.FMSConfigManager.getFSCConfig(FMSConfigManager.java:345)
at com.teamcenter.fms.config.FMSConfigManager.getFSCConfig(FMSConfigManager.java:260)
at com.teamcenter.fms.servercache.FSCConfigManager.getConfig(FSCConfigManager.java:161)
at com.teamcenter.fms.servercache.FMSServerCache.configure(FMSServerCache.java:508)
at com.teamcenter.fms.servercache.FMSServerCache.instanceMain(FMSServerCache.java:279)
at com.teamcenter.fms.servercache.FMSServerCache.main(FMSServerCache.java:213)
Please help me how to solve this
Dear Randy
I have solved the first issue
I am getting some new error
2016/06/30-04:25:40,936 UTC MLD Log init: com.teamcenter.mld version 1.0.2 (2009-01-21)
INFO - 2016/06/30-04:25:41,154 UTC - AMW-WS-056 - FMSServerCache starting...
INFO - 2016/06/30-04:25:41,154 UTC - AMW-WS-056 - FMSServerCache version: 8.2, build date: 20110407
INFO - 2016/06/30-04:25:41,154 UTC - AMW-WS-056 - FMSUtil version: 8.2, build date: 20110407
INFO - 2016/06/30-04:25:41,154 UTC - AMW-WS-056 - FSCJavaClientProxy version: 8.2, build date: 20110407
INFO - 2016/06/30-04:25:41,154 UTC - AMW-WS-056 - java.vm.version: 14.0-b16
INFO - 2016/06/30-04:25:41,154 UTC - AMW-WS-056 - java.vm.vendor: Sun Microsystems Inc.
INFO - 2016/06/30-04:25:41,154 UTC - AMW-WS-056 - java.vm.info: mixed mode
INFO - 2016/06/30-04:25:41,154 UTC - AMW-WS-056 - java.io.tmpdir: C:\Users\infodba\AppData\Local\Temp\
INFO - 2016/06/30-04:25:41,154 UTC - AMW-WS-056 - java.library.path: C:\APLM\Siemens\TEAMCE~1\fsc/lib
INFO - 2016/06/30-04:25:41,154 UTC - AMW-WS-056 - file.encoding: Cp1252
INFO - 2016/06/30-04:25:41,170 UTC - AMW-WS-056 - line.separator: CRLF
INFO - 2016/06/30-04:25:41,170 UTC - AMW-WS-056 - user.name: infodba
INFO - 2016/06/30-04:25:41,170 UTC - AMW-WS-056 - user.home: C:\Users\infodba
INFO - 2016/06/30-04:25:41,170 UTC - AMW-WS-056 - user.dir: C:\APLM\Siemens\TEAMCE~1\fsc
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - ********************************************************************
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - Master FSC Path = fmsmaster_FSC_AMWWS056_infodba.xml
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - Local FSCId = FSC_AMWWS056_infodba
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - Local enterpriseId = -2096877821
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - FSC Configuration master path: fmsmaster_FSC_AMWWS056_infodba.xml
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - FSC Configuration local path: FSC_AMWWS056_infodba.xml
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - FSC configuration is complete using a locally served FMS master configuration file.
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - Configuration backup file already exists: C:\APLM\Siemens\TEAMCE~1\fsc/confighistory/-2096877821-18423d6188555ab96a7e9c16125714b6-fmsmaster_FSC_AMWWS056_infodba.xml
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - Located configuration for FSC: 'FSC_AMWWS056_infodba'
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - volume 09605325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\MKTG_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - volume 04d74e4294e183042f03(E:\\TC_APLM\\VOL\\PEP\\ELE_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - volume 095a5325855e83042f03(E:\\TC_APLM\\VOL\\PEP\\FINANCE_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,357 UTC - AMW-WS-056 - volume 09695325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\PPC_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,373 UTC - AMW-WS-056 - volume 09815325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\VD_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,373 UTC - AMW-WS-056 - volume 096c5325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\PROC_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,373 UTC - AMW-WS-056 - volume 04e34e4294e183042f03(C:\\TC_APLM\\VOL\\PEP\\SPN_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,373 UTC - AMW-WS-056 - volume 09725325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\QUALITY_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,373 UTC - AMW-WS-056 - volume 09635325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\MAT_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,373 UTC - AMW-WS-056 - volume 097b5325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\STORES_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,373 UTC - AMW-WS-056 - volume 04da4e4294e183042f03(E:\\TC_APLM\\VOL\\PEP\\FRA_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,373 UTC - AMW-WS-056 - volume 095d5325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\LQA_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,373 UTC - AMW-WS-056 - volume 08865325855e83042f03(E:\\TC_APLM\\VOL\\PEP\\FLD_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,388 UTC - AMW-WS-056 - volume 096f5325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\PROD_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,388 UTC - AMW-WS-056 - volume 03d14e42909183042f03(E:\\TC_APLM\\VOL\\PEP\\CAB_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,388 UTC - AMW-WS-056 - volume 04e64e4294e183042f03(E:\\TC_APLM\\VOL\\PEP\\ENG_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,388 UTC - AMW-WS-056 - volume 03c24e4294e183042f03(E:\\TC_APLM\\VOL\\PEP\\DRV_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,388 UTC - AMW-WS-056 - volume 04e94e4294e183042f03(C:\\TC_APLM\\VOL\\PEP\\WHT_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,388 UTC - AMW-WS-056 - volume 04dd4e4294e183042f03(C:\\TC_APLM\\VOL\\PEP\\STR_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,388 UTC - AMW-WS-056 - volume 04ec4e4294e183042f03(E:\\TC_APLM\\VOL\\PEP\\CHS_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,388 UTC - AMW-WS-056 - volume 097e5325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\VQIG_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,388 UTC - AMW-WS-056 - volume 04e04e4294e183042f03(E:\\TC_APLM\\VOL\\PEP\\BRK_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,404 UTC - AMW-WS-056 - volume 00f34e3fde9183042f03(D:\TC_APLM\Siemens\volume1) write/read/content verified.
INFO - 2016/06/30-04:25:41,404 UTC - AMW-WS-056 - volume 09665325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\ME_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,404 UTC - AMW-WS-056 - volume 09785325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\SQA_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,404 UTC - AMW-WS-056 - volume 09755325855e83042f03(C:\\TC_APLM\\VOL\\PEP\\SPARES_VOL) write/read/content verified.
INFO - 2016/06/30-04:25:41,404 UTC - AMW-WS-056 - transientvolume 2ead6de0df8efbd90f03f48777d048ca(C:\\Temp\\transientVolume_infodba) write/read/content verified.
ERROR - 2016/06/30-04:25:41,420 UTC - AMW-WS-056 - The configured v100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:385) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2016/06/30-04:25:41,420 UTC - AMW-WS-056 - The configured F100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:392) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2016/06/30-04:25:41,420 UTC - AMW-WS-056 - The configured M050 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:399) com.teamcenter.fms.servercache.FMSServerCache
WARN - 2016/06/30-04:25:41,420 UTC - AMW-WS-056 - The fscadmin command 'filestoredetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
WARN - 2016/06/30-04:25:41,420 UTC - AMW-WS-056 - The fscadmin command 'cachedetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
INFO - 2016/06/30-04:25:41,435 UTC - AMW-WS-056 - Read Fast Cache initialized at: C:\Users\infodba/FSCCache/FSC_AMWWS056_infodba/read
INFO - 2016/06/30-04:25:41,435 UTC - AMW-WS-056 - Read Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO - 2016/06/30-04:25:41,435 UTC - AMW-WS-056 - Write Fast Cache initialized at: C:\Users\infodba/FSCCache/FSC_AMWWS056_infodba/write
INFO - 2016/06/30-04:25:41,435 UTC - AMW-WS-056 - Write Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO - 2016/06/30-04:25:41,451 UTC - AMW-WS-056 - Whole File Cache disabled at: C:\Users\infodba\FSCCache
INFO - 2016/06/30-04:25:41,451 UTC - AMW-WS-056 - Whole File Cache parameter values: filespersubdir=0,maxfileage=(3650/30),percentfree=30,purgewait=(0/30),purgecycle=(240/30),partitions=(1/0)
validateTickets=true
INFO - 2016/06/30-04:25:42,215 UTC - AMW-WS-056 - LogLevel set to WARN
FATAL - 2016/06/30-04:25:42,465 UTC - AMW-WS-056 - Error during initialization. com.teamcenter.fms.servercache.FMSServerCache
org.mortbay.util.MultiException[java.net.SocketException: Unrecognized Windows Sockets error: 0: JVM_Bind]
at org.mortbay.http.HttpServer.start(HttpServer.java:640)
at com.teamcenter.fms.servercache.FMSServerCache.startServer(FMSServerCache.java:903)
at com.teamcenter.fms.servercache.FMSServerCache.instanceMain(FMSServerCache.java:361)
INFO - 2016/06/30-04:25:42,465 UTC - AMW-WS-056 - Whole File Cache shutdown.
INFO - 2016/06/30-04:25:42,480 UTC - AMW-WS-056 - Read Fast Cache shutdown.
INFO - 2016/06/30-04:25:42,480 UTC - AMW-WS-056 - Write Fast Cache shutdown.
please help
I can't tell if you're using the default port 4544 or some other. It looks like you solved the duplicate volume id issue, hopefully using backup_xmlinfo, to find the real volume id and fix it in the FMS Master.
I recommend that you stop the FSC's and delete the read/write cache directories. Restart the FSC's so that the updated FMS Master is downloaded and a new read/write cache is created. Review the FSC_*.stdout for the successful message and if not present then review the FSC_*.stderr for more information.
The error listed above could be received if the cache was corrupted. Or it could be a port conflict. Or...
Evaluating: AW 3.4
