unable to start FSC service
Siemens Creator
Hi ,
          I am not able to start the FSC. Got the below error.
2016/07/20-16:24:55,921 UTC MLD Log init: com.teamcenter.mld version V9000.1.0.20_20120806.00 (20121015)
log.properties found at /opt/plmshare/tc/tc_root/tplm05/tc112/fsc/log.properties
OS name is Linux
JVM vendor is Oracle Corporation
Data model is 64
INFO  - 2016/07/20-16:24:56,350 UTC - plm-tcl-tapp05 - FMSServerCache starting...
INFO  - 2016/07/20-16:24:56,350 UTC - plm-tcl-tapp05 - FMSServerCache version: 11.2.2, build date: 20160411
INFO  - 2016/07/20-16:24:56,351 UTC - plm-tcl-tapp05 - FMSUtil version: 11.2.2, build date: 20160411
INFO  - 2016/07/20-16:24:56,351 UTC - plm-tcl-tapp05 - FSCJavaClientProxy version: 11.2.2, build date: 20160411
INFO  - 2016/07/20-16:24:56,351 UTC - plm-tcl-tapp05 - java.vm.version: 25.72-b15
INFO  - 2016/07/20-16:24:56,351 UTC - plm-tcl-tapp05 - java.vm.vendor: Oracle Corporation
INFO  - 2016/07/20-16:24:56,351 UTC - plm-tcl-tapp05 - java.vm.info: mixed mode
INFO  - 2016/07/20-16:24:56,352 UTC - plm-tcl-tapp05 - java.io.tmpdir: /opt/global_logs/tplm05_log/fsc/plm-tcl-tapp05/log4j
INFO  - 2016/07/20-16:24:56,352 UTC - plm-tcl-tapp05 - java.library.path: /opt/plmshare/tc/tc_root/tplm05/tc112/fsc/lib
INFO  - 2016/07/20-16:24:56,352 UTC - plm-tcl-tapp05 - file.encoding: UTF-8
INFO  - 2016/07/20-16:24:56,359 UTC - plm-tcl-tapp05 - line.separator: LF
INFO  - 2016/07/20-16:24:56,359 UTC - plm-tcl-tapp05 - user.name: tcadmd
INFO  - 2016/07/20-16:24:56,359 UTC - plm-tcl-tapp05 - user.home: /home/tcadmd
INFO  - 2016/07/20-16:24:56,359 UTC - plm-tcl-tapp05 - user.dir: /opt/global_logs/tplm05_log/fsc/plm-tcl-tapp05
INFO  - 2016/07/20-16:24:56,560 UTC - plm-tcl-tapp05 - ********************************************************************
INFO  - 2016/07/20-16:24:56,560 UTC - plm-tcl-tapp05 - Master FSC Path = /opt/plmcommon/config/fsc/fmsmaster_tplm05.xml
INFO  - 2016/07/20-16:24:56,560 UTC - plm-tcl-tapp05 - Local FSCId = FSC_tplm05_plm-tcl-tapp05
INFO  - 2016/07/20-16:24:56,560 UTC - plm-tcl-tapp05 - Local enterpriseId = -1949210017
INFO  - 2016/07/20-16:24:56,562 UTC - plm-tcl-tapp05 - FSC Configuration master path: /opt/plmcommon/config/fsc/fmsmaster_tplm05.xml
INFO  - 2016/07/20-16:24:56,562 UTC - plm-tcl-tapp05 - FSC Configuration local path: /opt/plmcommon/config/fsc/FSC_tplm05_plm-tcl-tapp05.xml
INFO  - 2016/07/20-16:24:56,562 UTC - plm-tcl-tapp05 - FSC configuration is complete using a locally served FMS master configuration file.
INFO  - 2016/07/20-16:24:56,562 UTC - plm-tcl-tapp05 - Configuration backup file already exists: /opt/plmshare/tc/tc_root/tplm05/tc112/fsc/confighistory/-1949210017-437463184f070fbcf0aaa71c27e82f6d-fmsmaster_tplm05.xml
INFO  - 2016/07/20-16:24:56,562 UTC - plm-tcl-tapp05 - Located configuration for FSC: 'FSC_tplm05_plm-tcl-tapp05'
INFO  - 2016/07/20-16:24:56,563 UTC - plm-tcl-tapp05 - volume 00ed56b074fc8b750133(/opt/plmvolume/tplm05_volumes/tplm05/tplm05) write/read/content verified.
INFO  - 2016/07/20-16:24:56,563 UTC - plm-tcl-tapp05 - volume 7675549127a132710c69547ee0a66e6c(/opt/plmvolume/tplm05_volumes/tplm05/tplm05) write/read/content verified.
INFO  - 2016/07/20-16:24:56,563 UTC - plm-tcl-tapp05 - transientvolume 5a68ad557727c2dc18f4b394f0bfb57a(/opt/transientVol/tplm05) write/read/content verified.
ERROR - 2016/07/20-16:24:56,570 UTC - plm-tcl-tapp05 - The configured v100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:421) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2016/07/20-16:24:56,571 UTC - plm-tcl-tapp05 - The configured F100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:428) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2016/07/20-16:24:56,571 UTC - plm-tcl-tapp05 - The configured M050 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:435) com.teamcenter.fms.servercache.FMSServerCache
WARN  - 2016/07/20-16:24:56,572 UTC - plm-tcl-tapp05 - The fscadmin command 'filestoredetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
WARN  - 2016/07/20-16:24:56,572 UTC - plm-tcl-tapp05 - The fscadmin command 'cachedetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
INFO  - 2016/07/20-16:24:56,575 UTC - plm-tcl-tapp05 - Read Fast Cache initialized at: /opt/FSCCache/tplm05/FSC_tplm05_plm-tcl-tapp05/read
INFO  - 2016/07/20-16:24:56,575 UTC - plm-tcl-tapp05 - Read Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO  - 2016/07/20-16:24:56,575 UTC - plm-tcl-tapp05 - Write Fast Cache initialized at: /opt/FSCCache/tplm05/FSC_tplm05_plm-tcl-tapp05/write
INFO  - 2016/07/20-16:24:56,575 UTC - plm-tcl-tapp05 - Write Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO  - 2016/07/20-16:24:56,578 UTC - plm-tcl-tapp05 - Whole File Cache disabled at: /tmp/FSCCache
INFO  - 2016/07/20-16:24:56,578 UTC - plm-tcl-tapp05 - Whole File Cache parameter values: filespersubdir=0,maxfileage=(3650/30),percentfree=30,purgewait=(0/30),purgecycle=(240/30),partitions=(1/0)
Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/commons/collections/map/LRUMap
        at com.teamcenter.fms.servercache.TicketCache.<init>(TicketCache.java:62)
        at com.teamcenter.fms.servercache.FMSServerCache.instanceMain(FMSServerCache.java:362)
        at com.teamcenter.fms.servercache.FMSServerCache.main(FMSServerCache.java:243)
Caused by: java.lang.ClassNotFoundException: org.apache.commons.collections.map.LRUMap
        at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
        ... 3 more
INFO  - 2016/07/20-16:24:56,585 UTC - plm-tcl-tapp05 - Whole File Cache shutdown.
INFO  - 2016/07/20-16:24:56,585 UTC - plm-tcl-tapp05 - Read Fast Cache shutdown.
INFO  - 2016/07/20-16:24:56,585 UTC - plm-tcl-tapp05 - Write Fast Cache shutdown.
Re: unable to start FSC service
Looks like a java issue. Check that your version is compatible with Tc11.2.2 and that your environment variables are set up correctly to find that version. You should review TC_ROOT\fsc\FSC_*.stderr for more clues on the cause of the failure.
Evaluating: AW 3.4
Siemens Creator
Hi Randy,
Thanks for the direction. It was a problem of fsc\third_party\*.jars were pointing to invalid jar files. After made the changes to fscadmin.sh with the right paths it is working now.
I am trying to install Teamcenter 10.1 on Centos machine .The environment is created using Docker .
When i am trying to install Teamcenter, it is throwing an error stating that it is unable to start FSC service.
FSC_1ccb80b52679_root_startup.log
2017/09/27-05:25:58,097 UTC MLD Log init: com.teamcenter.mld version V9000.1.0.2
log.properties found at /usr/Siemens/Teamcenter10/fsc/log.properties
OS name is Linux
Data model is 64
INFO - 2017/09/27-05:25:59,494 UTC - 1ccb80b52679 - FMSServerCache starting...
INFO - 2017/09/27-05:25:59,494 UTC - 1ccb80b52679 - FMSServerCache version: 10.
1, build date: 20130514
INFO - 2017/09/27-05:25:59,494 UTC - 1ccb80b52679 - FMSUtil version: 10.1, buil
d date: 20130514
INFO - 2017/09/27-05:25:59,505 UTC - 1ccb80b52679 - FSCJavaClientProxy version:
10.1, build date: 20130514
INFO - 2017/09/27-05:25:59,505 UTC - 1ccb80b52679 - java.vm.version: 24.80-b11
INFO - 2017/09/27-05:25:59,505 UTC - 1ccb80b52679 - java.vm.vendor: Oracle Corp
oration
INFO - 2017/09/27-05:25:59,505 UTC - 1ccb80b52679 - java.vm.info: mixed mode
INFO - 2017/09/27-05:25:59,505 UTC - 1ccb80b52679 - java.io.tmpdir: /tmp
INFO - 2017/09/27-05:25:59,505 UTC - 1ccb80b52679 - java.library.path: ./lib
INFO - 2017/09/27-05:25:59,506 UTC - 1ccb80b52679 - file.encoding: ANSI_X3.4-19
68
INFO - 2017/09/27-05:25:59,546 UTC - 1ccb80b52679 - line.separator: LF
INFO - 2017/09/27-05:25:59,546 UTC - 1ccb80b52679 - user.name: root
INFO - 2017/09/27-05:25:59,546 UTC - 1ccb80b52679 - user.home: /root
INFO - 2017/09/27-05:25:59,547 UTC - 1ccb80b52679 - user.dir: /usr/Siemens/Team
center10/fsc
INFO - 2017/09/27-05:26:00,068 UTC - 1ccb80b52679 - ***************************
INFO - 2017/09/27-05:26:00,068 UTC - 1ccb80b52679 - Master FSC Path = ./fmsmast
er_FSC_1ccb80b52679_root.xml
INFO - 2017/09/27-05:26:00,068 UTC - 1ccb80b52679 - Local FSCId = FSC_1ccb80b52
679_root
INFO - 2017/09/27-05:26:00,068 UTC - 1ccb80b52679 - Local enterpriseId = 0
INFO - 2017/09/27-05:26:00,075 UTC - 1ccb80b52679 - FSC Configuration master pa
th: ./fmsmaster_FSC_1ccb80b52679_root.xml
INFO - 2017/09/27-05:26:00,075 UTC - 1ccb80b52679 - FSC Configuration local pat
h: ./FSC_1ccb80b52679_root.xml
INFO - 2017/09/27-05:26:00,075 UTC - 1ccb80b52679 - FSC configuration is comple
INFO - 2017/09/27-05:26:00,076 UTC - 1ccb80b52679 - Configuration history saved
: /usr/Siemens/Teamcenter10/fsc/confighistory/0-d66fa01e900f78510987f591caa7177e
-fmsmaster_FSC_1ccb80b52679_root.xml
INFO - 2017/09/27-05:26:00,076 UTC - 1ccb80b52679 - Located configuration for F
SC: 'FSC_1ccb80b52679_root'
ERROR - 2017/09/27-05:26:00,106 UTC - 1ccb80b52679 - The configured v100 encrypt
ketingAndEncryption(FMSServerCache.java:417) com.teamcenter.fms.servercache.FMSS
erverCache
ERROR - 2017/09/27-05:26:00,107 UTC - 1ccb80b52679 - The configured F100 encrypt
ketingAndEncryption(FMSServerCache.java:424) com.teamcenter.fms.servercache.FMSS
erverCache
ERROR - 2017/09/27-05:26:00,108 UTC - 1ccb80b52679 - The configured M050 encrypt
ketingAndEncryption(FMSServerCache.java:431) com.teamcenter.fms.servercache.FMSS
erverCache
WARN - 2017/09/27-05:26:00,108 UTC - 1ccb80b52679 - The fscadmin command 'files
WARN - 2017/09/27-05:26:00,108 UTC - 1ccb80b52679 - The fscadmin command 'cache
INFO - 2017/09/27-05:26:00,141 UTC - 1ccb80b52679 - Read Fast Cache initialized
at: /tmp/FSCCache/FSC_1ccb80b52679_root/read
INFO - 2017/09/27-05:26:00,142 UTC - 1ccb80b52679 - Read Fast Cache parameter v
INFO - 2017/09/27-05:26:00,154 UTC - 1ccb80b52679 - Write Fast Cache initialize
d at: /tmp/FSCCache/FSC_1ccb80b52679_root/write
INFO - 2017/09/27-05:26:00,154 UTC - 1ccb80b52679 - Write Fast Cache parameter
INFO - 2017/09/27-05:26:00,318 UTC - 1ccb80b52679 - Whole File Cache disabled a
t: /tmp/FSCCache
INFO - 2017/09/27-05:26:00,318 UTC - 1ccb80b52679 - Whole File Cache parameter
validateTickets=true
INFO - 2017/09/27-05:26:01,136 UTC - 1ccb80b52679 - LogLevel set to WARN
05:26:01.358 EVENT Starting Jetty/4.2.x
05:26:01.389 EVENT Started HttpContext[/]
05:26:01.390 EVENT Started SocketListener on 0.0.0.0:4544
05:26:01.390 EVENT Started org.mortbay.http.HttpServer@12aea1a2
INFO - 2017/09/27-05:26:01,391 UTC - 1ccb80b52679 - Server Initialization succe
ssful, server is started.
Please help me in resolving the above issue
Those are not really errors. V100, F100, M050 are related to generating an fms.key file using the keygen tool and the install_encryptionkeys utility. After generating the rijndaelkey and putting it in the fms.key file then you would add the lines to the FMS Master between the <fmsenterprise> and <fccdefaults> tags.
<!--- Required FMS key encryption tags -->
<ticket version="v100" keyfile="./fms.key" />
<ticket version="M050" keyfile="./fms.key" />
<ticket version="F100" keyfile="./fms.key" />
Your FSC service started just fine. The line in the log that tells you everything is ok:
Server Initialization successful, server is started.
Evaluating: AW 3.4
HI randy,
Thanks for the quick reply
Agreed that FSc service is started but installer is interrupted with below logs saying failed to start FSC daemon
*** Processing block FMS Server Cache/install:0
Running com.teamcenter.install.tceng.fms.fsc.Fsc
*** Running com.teamcenter.install.tceng.fms.fsc.Fsc
Executing com.teamcenter.install.tceng.fms.fsc.Fsc
Updating fsc.xml
Loading /usr/Siemens/Teamcenter10/fsc/fsc.xml.template
Change FSC_MaximumReadCacheExtentFiles from [3] to [0]
Change FSC_ReadCacheHashBlockPages from [2048] to [32]
Add FSC_ReadCachePurgePolicy value [age]
Change FSC_MaximumReadCacheExtentFileSizeMegabytes from [256] to [16]
Change FSC_MaximumReadCacheSegments from [9216] to [623]
Change FSC_MaximumReadCacheFilePages from [40960] to [512]
Change FSC_ReadCacheLocation from [$HOME\FSCCache|/tmp/FSCCache] to [/tmp/FSCCache]
Add FSC_WriteCachePurgePolicy value [age]
Change FSC_MaximumWriteCacheSegments from [9216] to [623]
Change FSC_WriteCacheLocation from [$HOME\FSCCache|/tmp/FSCCache] to [/tmp/FSCCache]
Change FSC_MaximumWriteCacheExtentFiles from [3] to [0]
Change FSC_MaximumWriteCacheFilePages from [40960] to [512]
Change FSC_WriteCacheHashBlockPages from [2048] to [32]
Change FSC_MaximumWriteCacheExtentFileSizeMegabytes from [256] to [16]
Change FSC_LogFile from [$HOME\$FSC_ID.log|/tmp/$FSC_ID.log] to []
Setting FSC ID to FSC_d244af9c78d9_root
Setting FSC to FMS Master
Saving FSC to /usr/Siemens/Teamcenter10/fsc/FSC_d244af9c78d9_root.xml
Creating fmsmaster
Add FCC_CacheLocation value [$HOME/FCCCache|/tmp/$USER/FCCCache]
Add FCC_MaxWriteCacheSize value [50M]
Add FCC_MaxReadCacheSize value [100M]
Add FCC_LogFile value [$HOME/fcc.log|/tmp/$USER/fcc.log]
Add FCC_MaximumNumberOfFilePages value [40960]
Add FCC_MaximumNumberOfSegments value [512]
Add FCC_HashBlockPages value [2048]
Add FCC_MaxExtentFiles value [32]
Add FCC_MaxExtentFileSizeMegabytes value [16]
Generating FSC master based on model: Simple Model
Setting default FSC for group mygroup to FSC_d244af9c78d9_root
Updating FCC Defaults
Change FCC_MaximumNumberOfSegments from [512] to [10688]
Change FCC_CacheLocation from [$HOME/FCCCache|/tmp/$USER/FCCCache] to [$HOME/FCCCache|/tmp/$USER/FCCCache]
Change FCC_MaxExtentFiles from [32] to [11]
Change FCC_HashBlockPages from [2048] to [6144]
Change FCC_MaximumNumberOfFilePages from [40960] to [28672]
Change FCC_MaxExtentFileSizeMegabytes from [16] to [256]
Change FCC_MaxWriteCacheSize from [50M] to [1000M]
Change FCC_MaxReadCacheSize from [100M] to [1000M]
Saving FMSMASTER to /usr/Siemens/Teamcenter10/fsc/fmsmaster_FSC_d244af9c78d9_root.xml
Installing FMS service (UNIX)
Setting 755 permissions for /usr/Siemens/Teamcenter10/fsc/rc.ugs.FSC_d244af9c78d9_root
Executing [chmod 755 /usr/Siemens/Teamcenter10/fsc/rc.ugs.FSC_d244af9c78d9_root]
Output from command:  chmod 755 /usr/Siemens/Teamcenter10/fsc/rc.ugs.FSC_d244af9c78d9_root
command_exit=0
Exit Status  0, elapsed time 0:00:00
Executing [cd "/usr/Siemens/Teamcenter10/fsc"]
Output from command:  cd "/usr/Siemens/Teamcenter10/fsc"
command_exit=0
Executing [/usr/Siemens/Teamcenter10/fsc/rc.ugs.FSC_d244af9c78d9_root]
Output from command:  /usr/Siemens/Teamcenter10/fsc/rc.ugs.FSC_d244af9c78d9_root
Starting FSC daemon FSC_d244af9c78d9_root on d244af9c78d9
\nERROR:  Failed to start fsc daemon.
Please refer to /tmp/FSC_d244af9c78d9_root_startup.log for error messages.
command_exit=1
Exit Status  1, elapsed time 0:02:08
An error occurred during execution.  Stack trace follows...
com.teamcenter.install.tceng.fms.fsc.Fsc.createFcsScript(Fsc.java:570)
com.teamcenter.install.tceng.fms.fsc.Fsc.unixInstall(Fsc.java:214)
com.teamcenter.install.tceng.fms.fsc.Fsc.installService(Fsc.java:200)
com.teamcenter.install.tceng.fms.fsc.Fsc.install(Fsc.java:96)
com.teamcenter.install.tem.tasks.JavaTask.execute(JavaTask.java:162)
com.teamcenter.install.tem.tasks.Task.execute(Task.java:115)
com.teamcenter.install.tem.tasks.blocks.CodeBlock.execute(CodeBlock.java:201)
com.teamcenter.install.tem.struct.TcFeature.processAction(TcFeature.java:1197)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:1135)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:1035)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:949)
com.teamcenter.install.tem.struct.TcFeature.install(TcFeature.java:874)
com.teamcenter.install.tem.director.actions.InstallAction.execute(InstallAction.java:29)
com.teamcenter.install.tem.director.DirectorScript.execute(DirectorScript.java:120)
com.teamcenter.install.tem.director.Director.run(Director.java:124)
java.lang.Thread.run(Thread.java:745)
***   CANCELLED
Installation interrupted due the following reason:
Processing <install> of feature FMS Server Cache failed: FSC service failed to start with an error 1
Time: Thu Sep 28 06:10:57 UTC 2017
when referred to /tmp/FSC_d244af9c78d9_root_startup.log it shows
USER_ID: 0, GROUP_ID: 0
bash-4.2# more FSC_d244af9c78d9_root_startup.log
2017/09/28-05:55:35,744 UTC MLD Log init: com.teamcenter.mld version V9000.1.0.2
OS name is Linux
Data model is 64
INFO  - 2017/09/28-05:55:37,693 UTC - d244af9c78d9 - FMSServerCache starting...
INFO  - 2017/09/28-05:55:37,695 UTC - d244af9c78d9 - FMSServerCache version: 10.
INFO  - 2017/09/28-05:55:37,696 UTC - d244af9c78d9 - FMSUtil version: 10.1, buil
d date: 20130514
INFO  - 2017/09/28-05:55:37,737 UTC - d244af9c78d9 - FSCJavaClientProxy version:
INFO  - 2017/09/28-05:55:37,737 UTC - d244af9c78d9 - java.vm.version: 24.80-b11
INFO  - 2017/09/28-05:55:37,737 UTC - d244af9c78d9 - java.vm.vendor: Oracle Corp
oration
INFO  - 2017/09/28-05:55:37,737 UTC - d244af9c78d9 - java.vm.info: mixed mode
INFO  - 2017/09/28-05:55:37,737 UTC - d244af9c78d9 - java.io.tmpdir: /tmp
INFO  - 2017/09/28-05:55:37,737 UTC - d244af9c78d9 - java.library.path: ./lib
INFO  - 2017/09/28-05:55:37,737 UTC - d244af9c78d9 - file.encoding: ANSI_X3.4-19
68
INFO  - 2017/09/28-05:55:37,849 UTC - d244af9c78d9 - line.separator: LF
INFO  - 2017/09/28-05:55:37,849 UTC - d244af9c78d9 - user.name: root
INFO  - 2017/09/28-05:55:37,849 UTC - d244af9c78d9 - user.home: /root
INFO  - 2017/09/28-05:55:37,850 UTC - d244af9c78d9 - user.dir: /usr/Siemens/Team
center10/fsc
INFO  - 2017/09/28-05:55:38,965 UTC - d244af9c78d9 - ***************************
INFO  - 2017/09/28-05:55:38,965 UTC - d244af9c78d9 - Master FSC Path = ./fmsmast
INFO  - 2017/09/28-05:55:38,965 UTC - d244af9c78d9 - Local FSCId = FSC_d244af9c7
8d9_root
INFO  - 2017/09/28-05:55:38,965 UTC - d244af9c78d9 - Local enterpriseId = 0
INFO  - 2017/09/28-05:55:38,967 UTC - d244af9c78d9 - FSC Configuration master pa
th: ./fmsmaster_FSC_d244af9c78d9_root.xml
INFO  - 2017/09/28-05:55:38,967 UTC - d244af9c78d9 - FSC Configuration local pat
h: ./FSC_d244af9c78d9_root.xml
INFO  - 2017/09/28-05:55:38,967 UTC - d244af9c78d9 - FSC configuration is comple
INFO  - 2017/09/28-05:55:38,968 UTC - d244af9c78d9 - Configuration history saved
: /usr/Siemens/Teamcenter10/fsc/confighistory/0-1b1d0ebc796d320592633eb4638b2830
-fmsmaster_FSC_d244af9c78d9_root.xml
INFO  - 2017/09/28-05:55:38,968 UTC - d244af9c78d9 - Located configuration for F
SC: 'FSC_d244af9c78d9_root'
ERROR - 2017/09/28-05:55:39,017 UTC - d244af9c78d9 - The configured v100 encrypt
erverCache
ERROR - 2017/09/28-05:55:39,021 UTC - d244af9c78d9 - The configured F100 encrypt
erverCache
ERROR - 2017/09/28-05:55:39,021 UTC - d244af9c78d9 - The configured M050 encrypt
erverCache
WARN  - 2017/09/28-05:55:39,022 UTC - d244af9c78d9 - The fscadmin command 'files
WARN  - 2017/09/28-05:55:39,022 UTC - d244af9c78d9 - The fscadmin command 'cache
INFO  - 2017/09/28-05:55:39,046 UTC - d244af9c78d9 - Read Fast Cache initialized
 at: /tmp/FSCCache/FSC_d244af9c78d9_root/read
INFO  - 2017/09/28-05:55:39,046 UTC - d244af9c78d9 - Read Fast Cache parameter v
INFO  - 2017/09/28-05:55:39,056 UTC - d244af9c78d9 - Write Fast Cache initialize
d at: /tmp/FSCCache/FSC_d244af9c78d9_root/write
INFO  - 2017/09/28-05:55:39,056 UTC - d244af9c78d9 - Write Fast Cache parameter
INFO  - 2017/09/28-05:55:39,064 UTC - d244af9c78d9 - Whole File Cache disabled a
t: /tmp/FSCCache
INFO  - 2017/09/28-05:55:39,064 UTC - d244af9c78d9 - Whole File Cache parameter
INFO  - 2017/09/28-05:55:39,210 UTC - d244af9c78d9 - LogLevel set to WARN
05:55:39.525 EVENT  Starting Jetty/4.2.x
05:55:39.563 EVENT  Started HttpContext[/]
05:55:39.574 EVENT  Started SocketListener on 0.0.0.0:4544
05:55:39.574 EVENT  Started org.mortbay.http.HttpServer@12aea1a2
INFO  - 2017/09/28-05:55:39,574 UTC - d244af9c78d9 - Server Initialization succe
The startup log shows that the service started successfully despite what TEM is showing when you initially installed. You will need to look elsewhere for root cause (small pun)...
Is it valid to install and run the FSC service as "root"?
The max sizes of the Read/Write cache being reduced from 3 to 0 is also concerning. Some files require the segment cache (like JT) and with maxsz 0 it will not be able to create a valid cache.
The log(s) you want to look at for clues as to why the install is misbehaving is:
FSC_d244af9c78d9_root.stderr
FSC_d244af9c78d9_root.stdout
Likely, the stdout file will show the error condition better than the other logs you have reviewed.
Evaluating: AW 3.4
Hello all,
Not able to install teamcenter whose version is (Tc11.2.0a_win64) . The error during installation says "The FSC is not responding. Start the FSC and click OK to continue"
Also FSC_HOME or FMS_HOME environment variables need not be set prior to Teamcenter installation. Please correct me if am wrong here..
Below is the stact trace from FSCID_fsc.log file from the TC_ROOT/fsc
INFO - 2018/02/14-10:31:17,050 UTC - LAPTOP-XXXXXXXX - Whole File Cache shutdown.
INFO - 2018/02/14-10:31:17,050 UTC - LAPTOP-XXXXXXXX - Read Fast Cache shutdown.
INFO - 2018/02/14-10:31:17,051 UTC - LAPTOP-XXXXXXXX - Write Fast Cache shutdown.
INFO - 2018/02/14-10:31:21,664 UTC - LAPTOP-XXXXXXXX - FMSServerCache starting...
INFO - 2018/02/14-10:31:21,664 UTC - LAPTOP-XXXXXXXX - FMSServerCache version: 11.1, build date: 20150712
INFO - 2018/02/14-10:31:21,665 UTC - LAPTOP-XXXXXXXX - FMSUtil version: 11.1, build date: 20150712
INFO - 2018/02/14-10:31:21,665 UTC - LAPTOP-XXXXXXXX - FSCJavaClientProxy version: 11.1, build date: 20150712
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - java.vm.version: 25.144-b01
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - java.vm.vendor: Oracle Corporation
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - java.vm.info: mixed mode
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - java.io.tmpdir: C:\Users\#####~1\AppData\Local\Temp\
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - java.library.path: D:\Siemens\Teamcenter11\fsc/lib
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - file.encoding: Cp1252
INFO - 2018/02/14-10:31:21,672 UTC - LAPTOP-XXXXXXXX - line.separator: CRLF
INFO - 2018/02/14-10:31:21,672 UTC - LAPTOP-XXXXXXXX - user.name: #####
INFO - 2018/02/14-10:31:21,672 UTC - LAPTOP-XXXXXXXX - user.home: C:\Users\#####
INFO - 2018/02/14-10:31:21,672 UTC - LAPTOP-XXXXXXXX - user.dir: D:\Siemens\Teamcenter11\fsc
INFO - 2018/02/14-10:31:21,949 UTC - LAPTOP-XXXXXXXX - ********************************************************************
INFO - 2018/02/14-10:31:21,949 UTC - LAPTOP-XXXXXXXX - Master FSC Path = fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:31:21,949 UTC - LAPTOP-XXXXXXXX - Local FSCId = FSC_Prol
INFO - 2018/02/14-10:31:21,949 UTC - LAPTOP-XXXXXXXX - Local enterpriseId = 0
INFO - 2018/02/14-10:31:21,956 UTC - LAPTOP-XXXXXXXX - FSC Configuration master path: fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:31:21,957 UTC - LAPTOP-XXXXXXXX - FSC Configuration local path: FSC_Prol.xml
INFO - 2018/02/14-10:31:21,957 UTC - LAPTOP-XXXXXXXX - FSC configuration is complete using a locally served FMS master configuration file.
INFO - 2018/02/14-10:31:21,957 UTC - LAPTOP-XXXXXXXX - Configuration backup file already exists: D:\Siemens\Teamcenter11\fsc/confighistory/0-021089d55ef80b74a8e58ce3250d8e11-fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:31:21,957 UTC - LAPTOP-XXXXXXXX - Located configuration for FSC: 'FSC_Prol'
ERROR - 2018/02/14-10:31:21,974 UTC - LAPTOP-XXXXXXXX - The configured v100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:424) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2018/02/14-10:31:21,975 UTC - LAPTOP-XXXXXXXX - The configured F100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:431) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2018/02/14-10:31:21,975 UTC - LAPTOP-XXXXXXXX - The configured M050 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:438) com.teamcenter.fms.servercache.FMSServerCache
WARN - 2018/02/14-10:31:21,976 UTC - LAPTOP-XXXXXXXX - The fscadmin command 'filestoredetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
WARN - 2018/02/14-10:31:21,976 UTC - LAPTOP-XXXXXXXX - The fscadmin command 'cachedetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
INFO - 2018/02/14-10:31:21,987 UTC - LAPTOP-XXXXXXXX - Read Fast Cache initialized at: C:\Users\#####/FSCCache/FSC_Prol/read
INFO - 2018/02/14-10:31:21,987 UTC - LAPTOP-XXXXXXXX - Read Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO - 2018/02/14-10:31:21,996 UTC - LAPTOP-XXXXXXXX - Write Fast Cache initialized at: C:\Users\#####/FSCCache/FSC_Prol/write
INFO - 2018/02/14-10:31:21,996 UTC - LAPTOP-XXXXXXXX - Write Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO - 2018/02/14-10:31:22,002 UTC - LAPTOP-XXXXXXXX - Whole File Cache disabled at: C:\Users\#####\FSCCache
INFO - 2018/02/14-10:31:22,002 UTC - LAPTOP-XXXXXXXX - Whole File Cache parameter values: filespersubdir=0,maxfileage=(3650/30),percentfree=30,purgewait=(0/30),purgecycle=(240/30),partitions=(1/0)
INFO - 2018/02/14-10:31:22,069 UTC - LAPTOP-XXXXXXXX - LogLevel set to WARN
INFO - 2018/02/14-10:31:22,238 UTC - LAPTOP-XXXXXXXX - Server Initialization successful, server is started.
INFO - 2018/02/14-10:32:00,134 UTC - LAPTOP-XXXXXXXX - Whole File Cache shutdown.
INFO - 2018/02/14-10:32:00,136 UTC - LAPTOP-XXXXXXXX - Read Fast Cache shutdown.
INFO - 2018/02/14-10:32:00,137 UTC - LAPTOP-XXXXXXXX - Write Fast Cache shutdown.
INFO - 2018/02/14-10:32:02,827 UTC - LAPTOP-XXXXXXXX - FMSServerCache starting...
INFO - 2018/02/14-10:32:02,828 UTC - LAPTOP-XXXXXXXX - FMSServerCache version: 11.1, build date: 20150712
INFO - 2018/02/14-10:32:02,828 UTC - LAPTOP-XXXXXXXX - FMSUtil version: 11.1, build date: 20150712
INFO - 2018/02/14-10:32:02,829 UTC - LAPTOP-XXXXXXXX - FSCJavaClientProxy version: 11.1, build date: 20150712
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - java.vm.version: 25.144-b01
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - java.vm.vendor: Oracle Corporation
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - java.vm.info: mixed mode
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - java.io.tmpdir: C:\Users\#####~1\AppData\Local\Temp\
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - java.library.path: D:\Siemens\Teamcenter11\fsc/lib
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - file.encoding: Cp1252
INFO - 2018/02/14-10:32:02,838 UTC - LAPTOP-XXXXXXXX - line.separator: CRLF
INFO - 2018/02/14-10:32:02,838 UTC - LAPTOP-XXXXXXXX - user.name: #####
INFO - 2018/02/14-10:32:02,838 UTC - LAPTOP-XXXXXXXX - user.home: C:\Users\#####
INFO - 2018/02/14-10:32:02,839 UTC - LAPTOP-XXXXXXXX - user.dir: D:\Siemens\Teamcenter11\fsc
INFO - 2018/02/14-10:32:03,076 UTC - LAPTOP-XXXXXXXX - ********************************************************************
INFO - 2018/02/14-10:32:03,077 UTC - LAPTOP-XXXXXXXX - Master FSC Path = fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:32:03,077 UTC - LAPTOP-XXXXXXXX - Local FSCId = FSC_Prol
INFO - 2018/02/14-10:32:03,077 UTC - LAPTOP-XXXXXXXX - Local enterpriseId = 0
INFO - 2018/02/14-10:32:03,077 UTC - LAPTOP-XXXXXXXX - ********************************************************************
INFO - 2018/02/14-10:32:03,082 UTC - LAPTOP-XXXXXXXX - FSC Configuration master path: fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:32:03,082 UTC - LAPTOP-XXXXXXXX - FSC Configuration local path: FSC_Prol.xml
INFO - 2018/02/14-10:32:03,082 UTC - LAPTOP-XXXXXXXX - FSC configuration is complete using a locally served FMS master configuration file.
INFO - 2018/02/14-10:32:03,082 UTC - LAPTOP-XXXXXXXX - Configuration backup file already exists: D:\Siemens\Teamcenter11\fsc/confighistory/0-021089d55ef80b74a8e58ce3250d8e11-fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:32:03,082 UTC - LAPTOP-XXXXXXXX - Located configuration for FSC: 'FSC_Prol'
ERROR - 2018/02/14-10:32:03,095 UTC - LAPTOP-XXXXXXXX - The configured v100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:424) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2018/02/14-10:32:03,096 UTC - LAPTOP-XXXXXXXX - The configured F100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:431) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2018/02/14-10:32:03,096 UTC - LAPTOP-XXXXXXXX - The configured M050 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:438) com.teamcenter.fms.servercache.FMSServerCache
WARN - 2018/02/14-10:32:03,096 UTC - LAPTOP-XXXXXXXX - The fscadmin command 'filestoredetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
WARN - 2018/02/14-10:32:03,096 UTC - LAPTOP-XXXXXXXX - The fscadmin command 'cachedetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
INFO - 2018/02/14-10:32:03,105 UTC - LAPTOP-XXXXXXXX - Read Fast Cache initialized at: C:\Users\#####/FSCCache/FSC_Prol/read
INFO - 2018/02/14-10:32:03,106 UTC - LAPTOP-XXXXXXXX - Read Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO - 2018/02/14-10:32:03,179 UTC - LAPTOP-XXXXXXXX - Write Fast Cache initialized at: C:\Users\#####/FSCCache/FSC_Prol/write
INFO - 2018/02/14-10:32:03,180 UTC - LAPTOP-XXXXXXXX - Write Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO - 2018/02/14-10:32:03,191 UTC - LAPTOP-XXXXXXXX - Whole File Cache disabled at: C:\Users\#####\FSCCache
INFO - 2018/02/14-10:32:03,191 UTC - LAPTOP-XXXXXXXX - Whole File Cache parameter values: filespersubdir=0,maxfileage=(3650/30),percentfree=30,purgewait=(0/30),purgecycle=(240/30),partitions=(1/0)
INFO - 2018/02/14-10:32:03,260 UTC - LAPTOP-XXXXXXXX - LogLevel set to WARN
INFO - 2018/02/14-10:32:03,418 UTC - LAPTOP-XXXXXXXX - Server Initialization successful, server is started.
Thanks..
Please start your own thread. This thread already has a solution for another user.
Evaluating: AW 3.4
