who assign TcServer to the client
I have a questions.
When I run the TC, tcserver will be assgin to the client TC for 4 tier as well as 2 tier to excute the logic.
But who assign each tc server to the client TC such as Pool Manager?
Re: who assign TcServer to the client
for a 4tier set-up the tcserver get assigned by the pool manager. You can monitor the assignment and a lot of other interesting things by logging in to the pool manager. With an explorer you can login using something like http://address of teamcenter serverSmiley Tongueort of pool manager with manager/manager. If I remeber correct default port is 8082.
HTH,
Xtof
