Quick, cost-effective CAD data management
Community Manager
How can I get CAD data management up and running quickly, and cost-effectively?
Platform_RapidStart_small.jpgConsider Teamcenter Rapid Start, the new preconfigured PDM solution from Siemens PLM Software, that can get you up and running with basic PDM in a matter of weeks. Teamcenter Rapid Start is simple to install and easy to maintain. You can deploy PDM quickly and cost-effectively, with minimal IT resources and investment, to achieve these benefits:
  • Reduce design cycle time
  • Increase design reuse
  • Manage engineering change
  • Improve design and engineering throughput
Read why Jim Brown, president of Tech-Clarity, recommends preconfigured CAD data management.
“PDM provides control, ease of access to information, and product data sharing outside of Engineering. But not all companies have the IT and business resources to implement such a solution. Smaller companies, in particular, require ease and speed of implementation and may not have an IT staff to support a significant installation effort. … For these companies, it is critical to find a PDM system that includes implementation wizards and an architecture that is easy to maintain. From a business perspective, the departments that will be using the system are also likely to be running lean and need to implement the solution rapidly and as efficiently as possible. These companies should look for solutions that provide best practices in the form of preconfigured data and workflows.”
For an even more cost-effective option, you can deploy Teamcenter Rapid Start on the cloud. Eliminate the up-front hardware costs, and manage your computing infrastructure on the cloud through affordable Amazon Web Services.
Best of all, because Teamcenter Rapid Start is a preconfiguration of standard Teamcenter, you can feel secure in the knowledge that you have chosen the world’s most widely deployed CAD data management solution. You can immediately realize the benefits with confidence that you have a growth path to PLM when you need it.
Learn more about what's included with Teamcenter Rapid Start by reading the fact sheet.
