Solid Edge CAD Data Management
Question
How can we manage Solid Edge CAD data?
Answer
AESSEAL.pngMany Solid Edge users are already reaping benefits from Teamcenter CAD data management. For example, AESSEAL, a manufacturer of mechanical seals for the oil and gas equipment industry has been able to reduce the time taken for the transfer of CAD design data to their business systems by 75 percent and significantly reduce errors at the same time. Read the full story here.
If you are a Solid Edge user, you already have access to a terrific software portfolio for product development, and with Solid Edge SP there is an excellent solution available for managing your Solid Edge files. But what if you want to take another step and investigate the possibilities for product data management (PDM) software to manage your CAD data and give you an entry point into the comprehensive capabilities of product lifecycle management (PLM)?
With Teamcenter, you can use CAD data management capabilities to take control of your Solid Edge CAD design data and processes. Find designs faster. Manage CAD data with internal and external partners. Put CAD data in the right context to improve productivity.
Read this article to learn how to get Solid Edge CAD data management up and running quickly and cost effectively.
