Tecnomatix Electronic Work Instructions (EWI) Delivered with Active Workspace Client for Teamcenter
Community Manager
Building on the value of MES-based electronic work instructions, Siemens PLM Software now offers an end-to-end, PLM-based solution for work instruction authoring and publishing. With the new release of the Active Workspace 2.1 client for Teamcenter, the Tecnomatix EWI 2.1 solution is now available on any smart device in a simple, task-specific user interface.
The basic concept is that the entire authoring process – from engineering design through manufacturing planning to shop floor execution – is performed using product lifecycle management (PLM) software. PLM applications support the workflow, and the work instruction data, including CAD-neutral visualization using the JT format. The PLM system manages electronic work instructions in one single source that spans the lifecycle, from Design to Manufacturing Planning to Process Instructions Planning to Execution.
Because the authoring process is managed using a single PLM backbone, your company reduces the risk of quality escapes, increases engineering efficiency and eliminates the need for data conversion. The PLM system supports smooth change management, minimizes data conversion and provides state-of-the-art 3D-based interactive authoring. Your company can realize significant savings in engineering time, as well as minimize time spent by manufacturing experts on the shop floor.
Learn more about the Teamcenter solution for Electronic Work Instructions by watching this demonstration video.
