A marshalling error occurred while opening JT dataset var "open in lifecycle visualization" button
Logged in as a non-dba user, I selected a JT dataset or an item revision which contains a DirectModel dataset, it says "A marshalling error occurred while processling XML for core-2008-06-session.log"
dba user will be fine.
How can I open jt file without error?
thank you!
Re: A marshalling error occurred while opening JT dataset var "open in lifecycle visualization&
Check your transient volume settings as the xml is written to the TV before passing to TcVis. Use backup_xmlinfo to validate the default transient volume id against the preference and against the FMS Master.
I met the same issue, the localization of an orgnization rule name contains special characters.
problem solved by removing localization of rule names.
