AWC 4.0 Customization Document
Is there any document available for AWC 4.0 Customization?
Re: AWC 4.0 Customization Document
Hi @Erez,
Thanks for sharing, your two first links seems very interesting (I already knew the third one).
Do you who is working on these projects ? Siemens ? (There's a siemens copyright on the first link apparently)
My main concern is : is it safe to use these ressources ?
Best regards,
Frédéric.
Thanks for your reply.
Can you have Angular JS related AWC customisation docs.
Satheeshkumar N.
Get Outlook for Android
