AWS Installation Error : feature_objdata_ftst.xml The element 'dispatcherModule' was unrecognized
After installing Teamcenter 11 2-tier and 4-tier, I am trying to install Tc11.2.1_ActiveWorkspace3.0.1_wntx64 through tem.bat. Update manager gives below error
Failed to load feature D:\TC11_installFiles\Tc11.2.1_ActiveWorkspace3.0.1_wntx64\wntx64\install\modules\feature_objdata_ftst.xml Unable to convert element [Element: ]>. java.lang.Exception: The element 'dispatcherModule' was unrecognized
Please see attached screenshot
Re: AWS Installation Error : feature_objdata_ftst.xml The element 'dispatcherModule' was unrecognize
Looks like there's an unsatisfied requirement for Dispatcher in order to install the FTS Indexer Client.
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
Thanks Arden for your response.
I am new tho AWS installation. Can you please guide me what I need to do to resolve this error ? Many Thanks in advance.
