Access on In Process Objects
Siemens Creator
Hello All,
        I have a requirement where we need to revoke access on in-process objects. It shall only be modifiable only to workflow participant, rest everyone shall not have write access on the objects.
I know we can create a workflow ACL where we give access only to workflow participant and everyone we revoke write access.
But as i have around 30-40 which i will have to modify. I was figuring if we have any configuration apart from workflow ACL we can achieve this without modifying workflows.
     Jayant
1 REPLY 1
Re: Access on In Process Objects
Duplicate post. Please only post the question once as it could be confusing if you are having different conversations within the different forums on the same subject.
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/Access-on-objects-wh...
Jamie
