Active Worksapce "AWS_FullTextSearch_Solr_URL" Prefernce help
Hello Experts,
I need a small help in Setting "AWS_FullTextSearch_Solr_URL" Preference in Teamcenter. As Active Workspace Search is not ideally functioning:( .
It gives me error:
Connections to the following search servers (Solr) were refused:
http://<Server Name>:<Port Number>/solr_admin/tcfts
The search has failed to perform.
Two Questions:
1. How do i check SOLR Connection. (FYI, I can login to Solr on this server, how to test the Connection)
2. Is there any format that we can manually set the "Value" for "AWS_FullTextSearch_Solr_URL" Preference?
Please Help.. Little Urgent as well..
Sameer
Re: Active Worksapce "AWS_FullTextSearch_Solr_URL" Prefernce help
Two Questions:
Make sure all the services running, you can test object data connectivity by using the following command:
runTcFTSIndexer -task=objdata:test
*Notes: if you can't connect, verify and update the Indexing Engine user credentials and/or Search Engine user credentials.
http://servername:portnumber/solr
*Notes : servername is where you installed Index Server Engine and default portnumber is 8983.
