Active Workspace: Failed to load viewer
Hello Everybody,
there is an issue with Active Workspace and its happenning by all the users by the customer.
In GTAC there is a solution but it's not 100% clear.
  • Symptom
    Failed to load Viewer in Active Workspace V3.1.2 when running https.
    Show more
  • Hardware/Software Configuration
  • Family: TEAMCENTER
    Application: ACTIVEWORKSPACE
    Function: VISUALIZATION
    Subfunction:
    Release: V3.1.2
    Show more
  • Solution
  • In jettyservice.properties" file define a path to your certificate
    VisPoolProxy.envset.TCVIS_CA_CERTS_FILE_LOCATION = path
Which certificate is meant?
Thx in Advance
M.
