Active Workspace Measurement
I use a german Teamcenter with german Active Workspace, and thus there is a [,] instead of [.] in decimal numbers.
I changed the unit from Meter to Centimeter and still i see a Comma [,] at the end of the number.
Example: 5, cm
Any idea how can I take this komma away if the number is an integer?
Thanks in Advance
1 REPLY
Re: Active Workspace Measurement
Could you please add some more details about the measurement?
Check the discussion. It may help.
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/decimal-point-input/td-p/305455
Ganesh
