Active Workspace quick search not showing any results
When I create an Item in TC and i search for it in the quick search, it doesn't show any results.
However advanced search works normally.
Any ideas guys?
Thanks.
Re: Active Workspace quick search not showing any results
It is a cutom quick search ?
Can you show your "Quick_Access_Queries_Attribute" preferences.
I'd like to follow up about the issue. I am experiencing the same thing. I apply the following filters to search for *:
Owner: Any
Type: Any
and pull up no results. However, if I search for * in the Advanced Search, I get results. Any ideas?
@SLR
Quick and advanced search are the same as in the Rich Client.
Does it work there?
Advanced search are predefined querries.
Quick search can be set as already mentioned by @benjamin1 in the "Quick_Access_Queries" and  "Quick_Access_Queries_Attribute" preferences.
@ekwan:
The settings Owner and Type are not used for quick search. They are used for the "index search".  Indexing has to be installed and customized for ActiveWorkspace.
Thank you @benjamin1 @Daniel_froehlich for your Reply:
These are the Preferences and their Values:
-Item ID
-Keyword Search
-Item Name
-Dataset Name
-Item ID_searchAttribute=ItemID
-Keyword Search_SearchAttribute=Keyword
-Item Name_SearchAttribute=ItemName
-Dataset Name_SearchAttribute=DatasetName
