Active workspace Declarative UI
Can we use declarative UI for creating sublocations under a business object like item revision.
I mean for now, we are using stylesheets to create sublocations(i.e pages and its data) under a business object.
Can we completely remove stylesheets and use declarative UI for creating sublocations under searched item revisions.
If so, while creating sublocation , what should we give as parent , I tried giving it as com_siemens_clientfx_tcui_xrt_showObject but did not show any results.
If I try to create sublocation giving parent as Search(i.e location), I am able to see my sublocation being created with declarative UI.
And in some document, I have found that for business objects we can use only stylesheet is that true???
Need immediate help on this.Thanks
Ramya.
