Active workspace search funcationality not working
I have configured active workspace to my environment. It is synced to teamcenter, as in I can select homefolder>newstuff>select, ect. Everything that exists in teamcenter exists in active workspace. However, when I try to perform the search function, it returns with no items found.
Where would I look to solve this issue?
ACW 3.0
TC 10.1.5
5 REPLIES 5
Re: Active workspace search funcationality not working
You may want to start looking into AWC indexing server. That is what configures AWC search.
For more details on how to configure TCFTSIndexer, refer to the AWC Configuration guide.
Swapnil Gawas
Testing, Teamcenter 11.2.x | Active Workspace 3.x
What I have found is that the active workspace indexing service will start, and stop shortly after. I will have to retrace my steps during the installation.
Looks like you have installed inexign as servieces so you don't need to start manually.
Go to services and check firts service (Sorted by Name) ActiveWorksapaceIndex...
And, check if the solar is working.
yogesh
Hi yog,
What do you mean by "solar is working"? I have not seen that before.
Solr is a search engine. You need it while working with AWS.
