Add Item ID to Description field During Drag and Drop Option
When a user drags and drops a document to an Item Revision from the users desktop is there an option where the description field is populated with what the Item Revision ID is.
thanks
Paul
Re: Add Item ID to Description field During Drag and Drop Option
Is there a reason why you want to put the info on the description? Putting it in the display name of the dataset or adding a compund property is pretty straightforward.
xtof
When users drag and drop documents against an order into Teamcenter from a local/network drive I needed a place that was out of the box OOTB where this could be done.  Then during a search of all documents against an order a user can easily view them.
thanks
Paul
Can you try adding $item_revision to the complexproperty property constant of object_desc of the dataset in BMIDE and see if it works. I have not tested it, but maybe it will work.
I had a llok at the online help. I think the idea with $item_revision does not work:
Siemens-Dokumentation
The ComplexProperty property constant applies only to the following business objects: Item , ItemRevision , Alias , Identifier , Dataset , and Form . In addition, source properties and the destination property must belong to the same object.
I think you first have to create a compound property like dataset.item_revision -> ItemRevision.object_name.
xtof
Happy New Year.
Thanks for the reply.  I am waiting for our Test server, so I can test.
I just went live a month ago.  I will keep you posted.
Paul
