Add dataset to Item revision with SOA TC Services
I have created a new dataset with TC services in Java. Now I want to add the dataset to an item revision, but how do I do that?
I need a method for adding dataset or other objects to an item revision.
Do someone know where to find documentation about the methods in TC Services. I have read the general documentation, but would like more info about the strucuture, methods and some examples as well.
Re: Add dataset to Item revision with SOA TC Services
hava a look at the function "DataManagementService.CreateRelations()" to create Relations between objects in Teamcenter.
cya
Thank you for input on this topic. I have used the service and function and it works perfect.
Just an extra info if someone wanted to do both create and add the dataset in one go:
com.teamcenter.services.strong.core._2010_04.Datamanagement.createDatasets
remember if you also add files(named references) with this you need to call the 2006 FileManagementService.commitDatasetFiles after createDatasets.
BR
Frank
