Add items
Hi.
As an administrator, if I click on a dataset I get an envelope to be able to send it, but as a normal user the envelope isn't there.
How do I add it to use as a user.  I also want to be able to add it to other users?
5 REPLIES 5
Re: Add items
Hi Dazzie
Users should be able to use the standard menu if you or your administrators did not suppress it
1) Select a dataset or several datasets Right Click on Mouse -> Send-To -> Envelope...
2) Select a dataset or several datasets File -> New -> Envelope...
Re: Add items
Hi Arthur.
Thanks for this infomation.
I ama new administrator.
How would I unsuppress the menu?
Re: Add items
This is an example of how to suppress an Envelope command for a dba group, you should check the group of users you need and remove the suppression of this command.
1) Add application Command Supression
2) Hide\Show command
Re: Add items
Addition: 3) do not forget to click save in application suppression commands
Re: Add items
Hi Arthur.
Got it thanks.
