Adding a component fails in teamcenter NX
receive a "Fatal Error" every time I try and add a part into an assembly
Re: Adding a component fails in teamcenter NX
You can try running part cleanup on the assy. OS error is bad, disk full? Missing C:\Temp?
Evaluating: AW 3.4
Reproduce the error and upload your NX syslog (Menu > Help > Log File) - you'll also find a copy in your temp directory.  You may have to set UGII_KEEP_SYSTEM_LOG=1 if the fatal error crashes the session and does not leave a syslog behind.
