Adding new Tool using BMIDE to open XML Files
Hi there,
I am currently new to Business Modeler IDE. I want to add the program Notepad++ using BMIDE as new tool in Teamcenter to open and edit XML file. On BMIDE I have created a new business object for the dataset and a new tool (see images below). After deploying, I can import the XML file, but I can't open it because the program wasn't defined correctly. What have I done wrong?
Best Regards
Kenneth
Re: Adding new Tool using BMIDE to open XML Files
Good afternoon, look at a similar topic, maybe this will help solve your problem:
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/issue-to-open-a-xml-...
Is it something as simple as needing a forward slash in your Shell/Symbol path, instead of the backward slash?
https://docs.plm.automation.siemens.com/tdoc/tc/12.1/help/#uid:xid369373
I tried to open Notepad++ using this directory with the back slash and it worked.
